Disabling buttons while they are still displayed on the viewer
UI version: 8.7.0
Core version: 8.7.5
I would like to disable a button but to continue to show it to users. I’ve tried adding a event listener on the button and prevent the default behaviour. Is there a way to do this?
The button would be clicked but the display would not change.
Every document
Not applicable
const ele = document.querySelector('[data-element="signatureToolGroupButton"]');
ele.addEventListener('click', (event) => {
        event.preventDefault();
instance.Core.documentViewer.addEventListener('toolModeUpdated', async (newToolMode, oldToolMode) => {
    console.log('toolModeUpdated');
    console.log('newToolMode');
    console.log(newToolMode);
    console.log('oldToolMode');
    console.log(oldToolMode);
You can add a ‘disabled’ prop to the element like this:
  instance.UI.updateElement('signatureToolGroupButton', {
        disabled: true
best regards,
Kevin
