We are using PDF.js Express Plus trail version to test the document embedded link clickable functionality before purchasing the product. We see document embedded links are clickable for few pages after that link is not clickable.
All embedded links in pdf document need to clickable.
Every document
Internal documents not able to access by outside.
Could you please provide the document that you’re experiencing this on?
Any custom code would be helpful to debug the issue as well.
Zach Serviss
Below is the actual document url which we are facing the issue in pdf viewer, embedded links are not able to clickable after 4th page.
(1-3 pages embedded links are working)
Could you please share how you are loading this document?
I notice you are using a very old version of express as well. Could you try this in the latest version? (8.7.0)
Zach Serviss
Thanks for that suggestion. We will upgrade the version for pdf.js express plus that we are using. Meanwhile I’m attaching a sample document here. When viewing this document using pdf.js express plus, the embedded links in the first 5 pages are clickable but from the 6th page onward, you’re unable to click on any embedded links in the document. Could you please validate the same at your end?
We are looking to purchase this product and would like this issue to be resolved at the earliest.
I am unable to reproduce the unclickable links. Please try this out in the demo site which is running version 8.7.0.
Zach Serviss
We upgraded to version 8.7.0 and that resolved the issue for the most part. For one particular document, when viewed in the pdf.js express plus viewer, the first URL on the page (Cisco Secure Endpoint (Formerly AMP for Endpoints) - Cisco) is not clickable. I tried uploading this document on the demo version but was unable to reproduce the issue. Could you please help debug why that one link is not working? File attached. cisco-amp-endpoints-privacy-data-sheet-1.pdf (181.4 KB)
I tried the document on express that was locally hosted and the link worked fine for me.
Could you send me how you are loading the document?
Zach Serviss
