How to get plan(PDF) detail as annotations differ in size(thickness) when same annotation drawn in both plans
Here in the below image, you can see that purple colored annotation with StrokeThickness = 4:
In this below image, It has the same purple colored annotation with StrokeThickness = 4:
I guess its with the plan’s(pdf) pixels or density. First plan is quite a big plan than second one. Also, note that here both plans have same scale set.
How to solve this issue. Is it possible to find a ratio and make thickness dynamic?
Annotations should be visible in same size irrespective of plan’s density.
Plans with high pixel density like first drawing.
First drawing.
Multipurpose hall - 1st Floor.pdf (160.4 KB)
Second drawing, respectively.
Single image.pdf (191.9 KB)
Instance.annotManager.setAnnotationStyles(annotation, annotation.StrokeThickness = 4);
This actually has to do with the zoom level when viewing the document. When you load a big document like your first example, we need to zoom way out in order to display the entire document. This means that annotations also appear zoomed out.
You have a few options here:
Set the zoom level to 100% by default:
instance.docViewer.on('documentLoaded', () => {
    instance.docViewer.zoomTo(1)
Or, get the zoom level and adjust the stroke thickness accordingly:
    instance.docViewer.getZoom()
  instance.docViewer.on('zoomUpdated', () => {
