UI version 6.3.3
Core version 6.3.3
All API requests have stopped working and responding with 504 after a VERY long interval (10 - 50 seconds).
var response = await fetch('https://api.pdfjs.express/xfdf/merge', {
mode: 'no-cors',
method: 'post',
body: data
}).then(resp => resp.json());
Guides:
APIs:
Forums:
May 12, 2022, 4:07pm
4
I cannot reproduce this issue - can you please send me a document you are having issues with?
I have used this editor last 2 3 years . Merge API stopped working the last few days, Now showing errors like the below-attached document.
Please check the below URL to find the issue.
https://medcoman.com/adminmedc/inspectors/edit_files_new/76
Email : demoinspector@medcoman.com
Password : demoinspector123!@#
Dear Logan,
Awaiting quick response to resolve the issue. suddenly it stopped working and we r in the dark with no proper support.
May 16, 2022, 2:06pm
7
I just checked the site you showed me and took a look at the network request to the merge API. It looks like you are providing a file URL that looks like so:
https://mft.medcoman.com:5443/rest/forms/v1/FIleUpload/payload/3564351c-8df3-43fc-86b4-737e413fbc67/file/f9e6e7a9-983f-4e01-a467-f48d87f0fd68
The URL is timing out when making requests to it which means the issue is coming from your end. Please make sure your mft.medcoman.com:5443 server is running correctly and is able to respond to requests.
