Internal PDF links are not working. The links don’t appear to be active and don’t respond to clicks. These documents render and respond correctly using the pdf.js in Firefox and in the PDF.js Express Plus Demo. As it’s supported by PDF.js is should be available in Express. Is there a setting in Express that disables the rendering of the links?
I’ve attached a sample doc with the links. Uploading to the Express Demo they will not work, Uploading the the Plus demo they do work.
