Customers use our website to view PDFs via proxies.
The links in our PDFs break their proxy behaviour.
E.g.
User goes to https://www-website-com.myproxy.tld/file and views PDF
PDF contains link to https://www.website.com/new
User clicks link, and is no longer loading the website via their proxy (so is effectively signed out)
The proxies re-write URLs for anything embedded in HTML, but can’t do the same for PDFs
Not expected, just wondering whether there’s a mechanism to re-write the URLs of embedded hyperlinks. E.g. something would see non-proxied url and change the bit before /new to the hostname.
N/A
N/A
N/A
I tried to use getAnnotationsManager().getAnnotationsList() but that didn’t result in objects that made sense to me.
Eg.
docViewer.on("annotationsLoaded", () => {
console.log("annotations loaded");
const annots = annotManager.getAnnotationsList();
annots.forEach((annotation) => {
//console.dir(annotation);
I wonder if I can do this using pdf-lib but I don’t know how I’d pass the PDF into the WebViewer
kkim
January 12, 2023, 7:05pm
4
For the hyperlinks in the PDF, you can see them as an annotation, for example in the demo site: PDF.js Viewer Demo | PDF.js Express
And these are types of link annotations we support:
Please note that the above guide is for express Pro, and the Viewer does not support link annotations: Internal links don't work in PDF.js Express viewer - #3 by system
Good to know, thank you Kevin!
