{I am experiencing an issue where the license key is being transmitted as a null value after obtaining and executing the license key.
Could you please advise on how to resolve this issue?}
{every document}
Please follow the guide here on entering your license key into your WebViewer constructor:
If the key is being transmitted as a null value, please double check that a variable you are using as a substitute for the licenseKey is actually the string value of the key. It may also help to clear your cache for some frameworks.
