We created a PDFExpress licence key, but when we try to test we get the following error message.
Some basic info::
| UI version |
‘8.7.0’ |
| Core version |
‘8.7.3’ |
| webviewer.min.js |
‘8.7.3’ |
| Build |
‘NS85LzIwMjN8YmNjNTg0NjlmNw==’ |
| WebViewer Server |
false |
| Full API |
false |
Any help would be really appreciated.
Hi developers1,
How are you passing the license key into the constructor?
Hi Tyler,
We are passing the key as per example in your repo on the Vue implementation
path: this.path,
initialDoc: `${process.env.BASE_URL}files/demo.pdf`,
licenseKey: 'My licence key',
this.$refs.viewer
).then((instance) => {
Just checked and it appears to still give the same error regarding the valid key.
Many thanks,
Jaap Migchels
Hello developers1,
Did you install PDFJS Express or PDFJS Express Viewer?
Did you resolve this? Same issue here.
Oddly the viewer worked with PDFJS Express instead of WebViewer.
