Landscape document print issue
We’re having issues when printing documents that use landscape orientation. When the document is processed and sent to the native print window, its orientation is changed to portrait, and changing between portrait and landscape in the print options doesn’t make any change.
We’re using pdfjs.express Plus v8.1.1.
Thank you.
Carlos H.
This is a known bug that we actually fixed (its just going through code review), so it should be fixed in the next release.
Thanks for the info. We’ll wait for the update then.
In what version was this fixed? I’m seeing the same behaviour in v8.2.1 (pdfjs-express-viewer).
