Make ZoomIn and ZoomOut buttons appear on mobile devices in portrait mode
I need to show ZoomIn and ZoomOut buttons when in mobile mode.
Currently the ZoomIn and ZoomOut buttons appear when in landscape mode for mobile devices.
Is there a way in the API to force the ZoomIn and ZoomOut header buttons to appear on smaller devices when in portrait mode?
Yes. I happens in very document.
Thank you for reaching out to pdf.js express forums,
We have the API enableDesktopOnlyMode that can help with smaller dimensions, but at about 640px wide it will still hide the zoomOverlayButton:
https://pdfjs.express/api/UI.html#.enableDesktopOnlyMode__anchor
One other way is to build your own custom UI via the following guide:
Thanks for your suggestion. Will try it out.
