Manage zoom in mobile using pinch
8.x.x
I cannot find how to manage the zoom events produced by pinching in mobile.
I have read that it should work out of the box. But it’s not my case.
I have tried on Android and IOS and the result is the same.
Our PDFs have to be compiled so there are forms present, I don’t know if this can cause a problem.
Do you have an example or snippet?
Hi Luis,
Thanks for your question.
One idea is that you can listen for the zoom event and check if this was on a mobile device. The following is a code snippet.
Webviewer({
}, document.getElementById('viewer')).then(instance => {
    documentViewer.addEventListener('zoomUpdated', (e) => {
     const isMobileDevice = window.navigator.userAgent.toLowerCase().includes("mobi");
      if(isMobileDevice) {
       // is pinching in a mobile device
Let me know if this works for you.
Thank you,
Dandara
