Outline navigation error
Just evaluating the react default web viewer example for the first time, no customizations.
When opening PDF’s that have outlines, navigation is not working, while it works in the default Chrome viewer. In the console I see “Tried to go to invalid bookmark destination”
Unfortunately I cannot currently provide the venders private documentation as example, but perhaps if there is some common format issue with outlines that can be provided, I might be able to convince them to transform their documents.
Hello tod.antilla,
Can you provide a sample document for us to test with?
