The viewer not displaying barcodes
I am uploading PDF files using the viewer; however, it is not recognizing the barcodes. It shows the value but not the code. I saw that another person had a similar related bug, but I haven’t found a solution yet.
The situation is peculiar because when I open the PDF with the browser, the barcode is displayed; however, when it’s in the viewer, it doesn’t, and only its value is shown.
I am using version 8.7.4.
Hello alexsmith,
Can you provide the file for us to test with?
Thank you!
Hi, thank you for the help, here is the document
docpdf.pdf (711.2 KB)
Hello alexsmith,
I was able to reproduce this issue and have put it in our backlog to be reviewed by our product team. Thank you.
Okay, I’ll stay attentive to any updates regarding this. Thank you very much.
@tgordon Hi, I was passing by here to ask what has happened with this matter? Any updates on it?
Hello alexsmith,
This issue is still in our backlog.
