Could you open the browser console log where you’re seeing these watermarks and send a screenshot?
Zach Serviss
Thanks for providing the screenshot. I suspect that the issue may stem from being attached on the incorrect domain. Which domain do you have attached to your license key?
Zach Serviss
Could you try attaching it to share.humecloud.com to see if that makes a difference?
Zach Serviss
Are you on the Viewer SDK and not the Express Plus SDK?
Zach Serviss
J’ai réussi à régler le problème en faisant attention de n’installer QUE le package “Viewer Only”.
J’ai aussi fait attention à bien renouveler mon cache.
Je vous laisse regarder mon poste.
Au passage, votre entreprise à l’air super intéressante et innovante ! Bon courage pour la suite !
Yes, sorry for my saying that earlier but the watermark will always appear when running localhost.
Zach Serviss
