WebViewer doesn't work in localhost
I’m using PDF.js Express Plus
Version 8.7.4
When I run my project on localhost:8082
web viewer doesn’t loaed
it shows AccessDenied Access DeniedGVNT22WT94SZNG58HjxTWdjItrHOdyN/nZzra8+2mls/rZEizY1cBCeyGQn9D4+D8V1eB6UeslpMdYZj7xXfYDV5Vr+3h6I+TTM/1adGAT4kIGRh0lZD760/l24=
but it works perfect on staging
web viewer should load PDF
with every document
‘https://pdftron.s3.amazonaws.com/downloads/pl/PDFTRON_about.pdf’,
import WebViewer from ‘@pdftron/pdfjs-express’
path: ${process.env.VUE_APP_PUBLIC_URL}/pdfjs-express,
licenseKey: process.env.VUE_PDFJS_EXPRESS_TOKEN!,
initialDoc:
quickSignViewer.value!
Thank you for posting the incident to our forum. We will provide you with an update as soon as possible.
It looks like from the code snippet, everything looks correct.
Could you make sure the url to the document is correct? It looks like when there is a symbol in the end of the URL, you will get a similar error message (note the ’ single quote in url):
It doesn’t matter which link I’m using
I also used ‘https://pdftron.s3.amazonaws.com/downloads/pl/demo-annotated.pdf’
but have got the same error
Thanks for your response,
If I go to the demo and enter the above url, I am able to load the document.
Do you have any network settings or browser extensions that are blocking the access? Does it work in incognito/private mode or another browser?
help me, no foun in my local domain, example: mydomain.local
A screenshot of error messages and even a minimal runnable sample project will help troubleshoot this issue.
