Ability to have an enter/exit function to fullscreen with their corresponding events
UI version : ‘8.7.0’
Core version : ‘8.7.4’
Is it possible to have different methods to enter/exit fullscreen mode on top of the toggleFullScreen as well as their corresponding event such as
UI.addEventListener('fullscreenModeToggled', (event) => {
    console.log(event)
    const detail = event.detail
    console.log(detail.isInFullscreen)
The issue I’m facing is that the toggleFullScreen method triggers only when we enter the fullscreen mode not when exiting.
Hello user67,
I was able to reproduce the issue where its not triggered when exiting the fullscreen mode.
As a workaround you can implement a custom button that toggles fullscreen which calls the toggleFullScreen API:
instance.UI.toggleFullScreen()
Let me know if that works for you.
Is there no way of fixing this or is this a limitation of the fullscreen api ?
Consequently, is there a way to extract the fullscreen button to the main header ?
I did venture a little bit through the api to add the button manually
       instance.UI.setHeaderItems((header) => {
            header.getHeader('default').push({
                img: UI.isFullscreen() ? 'icon-header-full-screen-exit' : 'icon-header-full-screen',
                index: -1,
                type: 'actionButton',
                title: 'Enter fullscreen',
                element: 'fullScreenButton',
                onClick: () => {
Is there any way to have a different img when toggeling the fullscreen mode as well change the text (Enter fullscreen / Exit fullscreen)
A quick side note,
when I click the fullscreen button, the event gets triggered correctly, the issue shows up when u press the escape button.
I am showing toolbar only in fullscreen mode. I am getting event for clicking exit full screen but when I press Escape button that time I didn’t get the event. any help for this?
