Cannot generate key for .gov.mv domains
=PDF.js Express Viewer=
UI version: 8.1.0
Core version: 8.1.1
It works fine on local server with .test domains and I am able to generate key for this type of urls without any issues.
I tried to generate a key for my production website but it says I don’t need to include subdomains but the root domain is actually xxxx.gov.mv (it only accepts [gov.mv] as the domain but it does not load the PDF from viewer I use that and test it).
Does not load pdf. Error message pops op in the console: Error: PDFJS.express: A valid license key is required to use the view only build of PDF.js Express. Get your free license key at (account required)
Every Document
We pushed an update to fix this issue. You should be able to use your domain properly now.
