Which product are you using? PDF.js Express Viewer
PDF.js Express Version 8.7.1
Currently, external PDF hyperlinks are rendered as <span> elements. How can I update the HTML markup so that they render as <a href="https://example.org"></a>?
Expected behaviour NA
Does your issue happen with every document, or just one? Every
Link to document NA
Code snippet NA
