PDF rendering issue in pdfjs express plus
We are experiencing an issue with text rendering using PDF.js Express Plus.
Some text does not render fully for some pages when viewing PDFs in the viewer, but the same PDFs display correctly in a standard browser that uses the default PDF.js renderer, which is also used by pdfjs-express as per the documentations and product description.
Attached document rendered with missing elements, such as text:
Document rendered as expected with standard browsers.
Attached document rendered correctly on Firefox:
A few documents.
https://esg.tcfhc.com.tw/uploads/download_item/download_file_en/12/2023_ESG_REPORT_en.pdf
Thank you for the bug report, I was able to reproduce the issue and have added this to the backlog for the product team to review.
best regards,
Kevin
Any news on the above?
Best,
Ons.
Unfortunately, we do not have any updates on this issue at this time.
We recommend you to consider switching to Apryse as it has ongoing updates and has the fix you are looking for:
best regards,
Kevin
