Text Rendering Issues in Chrome and Edge
I am seeing text getting screwed on Google Chrome and Edge, check attached screenshot of demo on your site. Looks good on Firefox though.
Any ideas what could be the issue here?
Hello,
I have the same issue in Chrome. Not always but often.
Just want to add that the text issues disappear when zooming in but return when zooming out. At least on our side.
Hope there is a solution.
Thomas
Yes, zoom in looks good but only above 200%. Its always bad at 100%
Thank you for reporting this.
I am on an M1 Mac and unable to see this issues, could you please share your CPU/GPU if applicable and OS?
Zach Serviss
Hello Zach,
These are the details which might be helpful in debugging this issue:
Processor 11th Gen Intel(R) Core™ i5-1155G7 @ 2.50GHz 2.50 GHz
Installed RAM 16.0 GB (15.8 GB usable)
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Edition Windows 11 Home Single Language
Version 22H2
Installed on ‎11/‎11/‎2022
OS build 22621.819
Experience Windows Feature Experience Pack 1000.22636.1000.0
Google Chrome
Version 107.0.5304.107 (Official Build) (64-bit)
Let me know if i need to share anything else, eager to see this issue fixed.
We also have multiple users reporting the same issue in our application.
We’re using PDFJS Express 8.6.0, but I don’t see anything related to this issue in the 8.7.0 release notes.
Here is a PDFTron solution for a similar problem.
Zach Serviss
These steps did fix the issue for me Zach, thank you for your inputs.
