Tried to go to invalid bookmark destination
Dear Team,
I am experiencing an issue with hyperlink navigation in the viewer outline section. When I click on a hyperlink that is supposed to take me to another page or a specific position within the same document, it does not work as expected.
Could you please look into this issue and advise on a possible resolution?
Thank you for your support.
Devaraju K
Tried to go to invalid bookmark destination when click hyperlink from outlines
Webviewer should go to clicked bookmark page.
Random document
Hello Devaraju,
Thank you for contacting PDFJS Express Forums.
To investigate further, are you able to provide a sample document with the hyperlinks not working as expected? This was our team can investigate if the hyperlink destination is valid.
Regards,
Luke
